Joined Surfaces
10783.1
This complex shape has been built up by joining surfaces. I've had success in the past composing this sort of thing into a usable solid, but not here - there's obviously something stopping that from happening.
Question: is there some tool or script available that will highlight edges/surfaces causing the problem? ( I mean short of zooming in close on every edge and inspecting it 'manually')
Size: 542.5 KB, Downloaded: 47 times, Dimensions: 1199x875px
10783.2
I should add I'm using v3 - and yes I've simplified the shape as much as I can ;)
10783.3 In reply to 10783.1
Hi Brendan, yes you can set up a script on a shortcut key that will highlight naked edges, see here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
If you can e-mail the .3dm file to me at moi@moi3d.com I can try to help you get it closed.
10783.4 In reply to 10783.3
As always, many thanks Michael!
I'll run the script & email if I'm still scratching my noggin :)
