How to make this solid?
 1-6  7-22
10782.7
Hey guys,
thank you so much for your answers!!
Today was so much wirk, I will try it again with your tips tomorrow.
I did not try do build it with the revolve-tool :)
I will tell you,
Thanks a lot
Koi
10782.8
He guys, thanks so much, i did it!
that was quiet easy... I thought I´m not a nooby anymore...
Thanks again and have a nice day
10782.9 In reply to 10782.2
Hey Brian,
thanks for your answer aswell! I tried this version today, works also :) I just think the way of michael is better, because I did not use exactly 90°..., so in other cases I can´t use revole I think?
koi
10782.10
I´m sorry, I got the next question :D
Now I tried a similiar solid: I just changed the profile curve more complexe. When I use shell, the surfaces on the bottom and left side are not flat anymore (2nd object). When I use b.diff. with a line(redline), the solid got a strange surface/ mistake on the side( 3rd object).
Is there any way o get a clean result?
Have a nice weekend,
koi
Size: 195.9 KB, Downloaded: 70 times, Dimensions: 948x1205px
10782.11 In reply to 10782.10
Trim with line can remove one sliver to make a flatish area.
Boolean Diff with plane can remove the other sliver, to make a flatish area.
But, near the inside corners, there are still tiny "folded over" edges.
10782.12 In reply to 10782.10
Hi koi, so for the bottom not being flat that's partly because your profile curve does not have an ending tangent that points straight downwards, it's angled like this:
So therefore the surface normal that a surface offset will go along will be like this:
I'm surprised that shell actually worked here because the surface you've generated is very strained and badly formed in the area where it collapses down to a point:
I'm not sure what your goal is for this protruding feature as it traverses towards the tip:
But you probably can't get a well formed result by just having that protruding feature directly collapse down to a point all on its own. You'll probably need some additional stations set up so that there isn't a complex shape with near undercuts in it as it collapses down. Something like this using Construct > Network (see attached 3dm) :
And it may be better to directly model the inner surface with its own set of curves rather than generating it with a surface offset.
- MIchael
EDITED: 30 Jul 2022 by MICHAEL GIBSON
10782.13 In reply to 10782.11
Hey Brian,
thanks for your answer.
Ißm not sure, if I understood completely right.. I tried to trim and to b.diff, but in both cases there remains a thin surface, like you can see in one of the fotos..
Do I understand you right?
-Koi
10782.14 In reply to 10782.12
Hey Michael,
thanks for this big answer!
"So therefore the surface normal that a surface offset will go along will be like this"
Ok, I understand that, but I need the small surfaces straight. This object should be a rain hood for bull's eye. so I need a straight side to be able to glue it down, I´ve got a picture for you. I want to build it with a 3D printer.
Is tehre any possiblity for that?
"And it may be better to directly model the inner surface with its own set of curves rather than generating it with a surface offset."
I´m not sure what you mean.. Actually I built that solid ffrom a surface with ´shell´. Firstly I tried to built it with profiles and networks. When I joined them in the end, I just got a joined surface every time..
On the other pictures, I tried to trick out the normals, but that did´nt work :D
I´m looking forward for your answer:)
-Koi
Size: 26.8 KB, Downloaded: 26 times, Dimensions: 516x474px
Size: 72.2 KB, Downloaded: 28 times, Dimensions: 743x565px
Size: 392.8 KB, Downloaded: 73 times, Dimensions: 633x584px
10782.15 In reply to 10782.14
I think that "surface offset" equals "shell".
One technique is to make the object a little bit longer, and trim off excess. But first the edge fold (surface fold), must be prevented.
Zooming in, it seems that the shell is causing an edge to fold back on itself, so avoiding shell would seem to be in order.
-Brian
ps, I Like your design.
I did move the trim plane by a tenth of a mm, or so.
10782.16 In reply to 10782.14
Hi Koi,
> every time..
The way Shell works for thickening an open surface is it builds a surface offset and then connects the edges.
Instead of using a surface offset method (including shell) it could be better to draw a second set of curves for the inner surface, creating it in the same way the outer surface was created.
10782.17 In reply to 10782.14
Hi Koi, here's a version built using Network twice, once for the outer surface and then a second network for the inner surface.
10782.18
Hey Brian and Michael,
I thank you so much! I love to learn how MoI and Nurbs are going!
I got your points.
I tried to make it solid with network aswell, but this was not possible, because I did not take a second profile on the sides to prevent overlapping?
Thanks so much, thid forum makes it defintely bigger!
thanks a lot,
Koi
10782.19
Hey guys,
it´s me again with a new question :)
I build a beautiful objetct with the sweep tool. And made this solid.
On the object is like a small seam to see, i made a screenshot aswell. Is it possible to get a nearly same result without that?
Best regards,
Koi
P.S. I am still working with V4 and, as you can see, not a real pro. Do you think I should switch on v5?
Size: 232.2 KB, Downloaded: 33 times, Dimensions: 876x619px
10782.20 In reply to 10782.19
Hi Koi, the problem is basically trying to do too much all in one single surfacing operation. If you try to force a sweep to go through too many shape changes it can result in a stressed surface that can have warping in the surface as it sort of tries to simultaneously pivot and stay squished together.
One method that might be good would be to use a one rail sweep like this: (with Twist = Flat option set)
That's going to make a more relaxed surface and then the top can be formed by a separate surface with a fillet or blend to transition between them:
Compare the surface control points between this sweep and your previous one, note how there is a lot heavier points and some strained areas where things are kind of bunching up. When you get the kind of "seam" like you were seeing it's sort of like too many forces applying stretching, shearing and rotation all at once in a small area and making little bumps.
10782.21 In reply to 10782.19
Hi Koi, so then to put on the top as a separate piece you do something like this - I made a taller version of the one rail sweep to have more material to work with, it looks a bit weird at top initially but it's ok that doesn't have any actual bunching or self intersections and it will be getting sliced off:
Set up a cross section and rail for the top cap something like this:
Sweep to make the top cap base surface, note that you want this to be a simple extended 4 sided surface so it can be a relaxed surface that you will trim instead of trying to force the initial surface shape directly to the ending boundary edge:
Offset cap surface since you're making a thin wall shape:
Trim surfaces with each other and join:
Apply a G2 fillet:
10782.22 In reply to 10782.19
Basically on your version trying to keep the top clamped together while also having the bottom rotate is just too many different shaping forces all trying to be applied at the same time.
2 rail sweep between rails of different lengths can also just generally apply a type of shearing type of effect as it is sliding things along the rails at different speeds and things can be prone to getting bunched up if they are also trying to do other kinds of shape transition at the same time.
Show messages:  1-6  7-22
