Importar OBJ a moi. Help
 1-2  3-22  23-28
10776.23 In reply to 10776.20
Or another way is to squish them flat using the edit frame. That can squish things flat in one direction at a time so you do it like this:
10776.24 In reply to 10776.23
Cool! Points are automatically collapsed merged ?
EDITED: 20 Jul 2022 by PILOU
10776.25 In reply to 10776.24
Hi Pilou, yes closed curves will automatically have the start and end control points represented by just one shared point.
10776.26 In reply to 10776.25
Excellent! (... for "closed curves!)
No closed curves here! )
Edit / Join must be done for collapse mutual points...(not made yet here)
10776.27 In reply to 10776.23
I see michael, your explanation is very helpful, when scaling two vertices in both directions it works as a collapse command (in case it is the same shape, if they are two different shapes you have to use the join command at the end) and when using the move command works like a target weld.
10776.28
Remember that the point thus created is a corner point! (edit/join or flat/flat)
- Zooen
Show messages:  1-2  3-22  23-28
