Cross Hatching experiment
1-14
15-34
35-54
55-62
Michael Gibson
15 Jul 2022 (15 of 62)
10774.15
In reply to
10774.14
> Some iso multiple+ &some Cmorph don't make some curves ?
That would definitely make some curves but not with the same kind of spacing and positioning.
How long would it take to generate curves all over like this for example? :
Here's another example - try placing isocurves and some Cmorph on this attached chess pawn model and try to get a result like this:
pawn.3dm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
15 Jul 2022 (16 of 62)
10774.16
In reply to
10774.15
You want this some ceramic skin erratic result ?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
15 Jul 2022 (17 of 62)
10774.17
In reply to
10774.16
Hi Pilou, try to make a result that looks like cross hatching like in a sketch.
Do a search for something like "cross hatching sketch" to see examples.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
wayne hill (WAYNEHILL5202)
16 Jul 2022 (18 of 62)
10774.18
It would be interesting to see the 3d cross hatching with the solid model hidden.
Wayne
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
16 Jul 2022 (19 of 62)
10774.19
In reply to
10774.18
Hi Wayne, here you go this one is the cross hatching all by itself, no edges or shading underneath.
Here is the same hatching with silhouettes added:
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
16 Jul 2022 (20 of 62)
10774.20
In reply to
10774.19
Thank you!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Larry Fahnoe (FAHNOE)
16 Jul 2022 (21 of 62)
10774.21
This is a wonderful collection of effects! I look forward to being able to use it as it does a really nice job of illustrating curvature. I particularly like the artistic nature of the hatching. Well done Michael!!
--Larry
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Marbleman
16 Jul 2022 (22 of 62)
10774.22
In reply to
10774.19
Hi Michael
Looks great with the silhouettes added, really handy.
www.jameselliott.co.uk
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
16 Jul 2022 (23 of 62)
10774.23
In reply to
10774.17
So it's that sort of effect that you want but made in Moi3D ?
My Moi French Site
My MagicaVoxel Gallery
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
16 Jul 2022 (24 of 62)
10774.24
In reply to
10774.22
Hi James, yeah I wasn't sure if the sketchy cross hatching would combine ok with the exact silhouettes but it seems fine together.
Michael
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
16 Jul 2022 (25 of 62)
10774.25
In reply to
10774.23
hi Pilou,
Yes, similar but with vector lines and curves being output, not as an image processing effect.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
16 Jul 2022 (26 of 62)
10774.26
In reply to
10774.25
Ok! :)
these hatching must also following the lighting of the object or must be isotropic ?
(from your examples seems isotropic)
EDITED: 16 Jul 2022 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
16 Jul 2022 (27 of 62)
10774.27
In reply to
10774.26
It's possible to do either.
The ones here adapt to lighting and have denser lines (smaller spacing) where the lighting is dark:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10774.2
This one does not respond to lighting:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10774.19
That will be an option that you will be able to set.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
16 Jul 2022 (28 of 62)
10774.28
In reply to
10774.27
ok...
Else in theory Flow function can't be used ?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
16 Jul 2022 (29 of 62)
10774.29
In reply to
10774.28
Not if you want it to look like real hatching - the pattern flowed on a sphere will be compressed at the pole areas and wider at the equator.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
16 Jul 2022 (30 of 62)
10774.30
In reply to
10774.29
Yes but you can make some Flow after a rotation of the sphere!
Sure the hatching will be not ultra regular but...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
16 Jul 2022 (31 of 62)
10774.31
In reply to
10774.30
Hi Pilou, that's too dense with too many lines crossing each other. It should only have 2 lines crossing each other at any single point like this:
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
16 Jul 2022 (32 of 62)
10774.32
In reply to
10774.15
Congrats!!
Maybe look at a "max length" type of value that can get rid of the "tidbits"... the little "outlying flyers"....
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
16 Jul 2022 (33 of 62)
10774.33
In reply to
10774.32
Thanks Burr! Yup I was also thinking of a minimum cutoff size parameter to cull stubby pieces.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
16 Jul 2022 (34 of 62)
10774.34
In reply to
10774.33
Righteous!
I feel your excitement! Like it's a long lost pal...
I wish you more of those to come this year!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
15-34
35-54
55-62
