How to create this kind of connection and the fillets for it?
All  1  2-4
10773.2 In reply to 10773.1
10773.3 In reply to 10773.2
Thank you Zarkow. That helped!
It's not exactly what I was looking for because I needed those "connections 6 times around the cylinder.. but your scetch with boolean helped me a lot, because I just created 6 boxes/cubes and rotated them around the cylinder center point and then booled them out!
By the way: What is the name of that thing in english? How can you call it?
10773.4 In reply to 10773.1
Hi Nikita3D,
is this what your after.
The problem is where the rib joins the hex and the top dia.
The flat on the hex is same width as the rib so you have to many edges converging.
I created a curve that gave a wider flat on the hex and also trimmed the rib and top dia.
This curve was revolved (caps off) and isect boolean .
This gave less converging edges and the fillet tool worked.
Hope thats clear.
Barry
Show messages: All  1  2-4
