Help button for add on scripts?
All  1-3  4-6
10768.4 In reply to 10768.3
Thanks Michael
I'll do some experimenting.
10768.5 In reply to 10768.3
The first method to have a help "button" is OK.
The hbox and flex method is very nice.
Is there a text editor to create messages in an alert box?
In the past I have had to use /n for newline and + and '
Well, just using text, not variables, would not be too hard...
Sample code:
moi.ui.alert( 'x1 = ' + x1 + ' cm' + '\n' + 'dValue = ' + dValue + ' cm' + '\n' + 'x0 = ' + x0 + ' cm' );
10768.6 In reply to 10768.5
That's the main way to do it. Sometimes it can be good to build it up in smaller chunks like
str += '...';
str += '...';
But there is also a string formatter you can use like this:
var x1 = 5, dValue = 3, x0 = 8;
var msg = moi.ui.formatString( 'x1 = %1% cm\ndValue = %2% cm\nx0 = %3% cm', x1, dValue, x0 );
moi.ui.alert( msg );
So for that way you have one "template string" that contains placeholders %1% , %2%, etc.. which are replaced by the values passed after the format string.
That method reduces the amount of little fragments that the regular way uses.
Show messages: All  1-3  4-6
