Help button for add on scripts?
All  1  2-6
10768.2 In reply to 10768.1
Hi Brian, if the UI for your script has a little space in the upper right corner of its command options UI, you could make a help button like this:
		<div style="position:absolute; right:0; top:0;">
			<moi:LabelButton onclick="moi.ui.alert('Help text here...');"><img src="moi://ui/icons/HelpIcon.png" style="width:2em;"/></moi:LabelButton>
		</div>
That will look like this:
But it won't make its own space there, it will be an overlay on top of other UI if there is something there.
You could put the button on its own line by removing the style="position:absolute; right:0; top:0;" from the above.
10768.3 In reply to 10768.1
Or maybe you could set the prompt text to be left aligned instead of centered and then that could make it a little easier to give the help button its own space, something like this:
<html>
	<body class="commandbody">
		<div class="commandheader" style="text-align:left; margin-bottom:0.5em;">
			<hbox style="align-items:center">
				<flex style="flex-shrink:1;">
					<div id="StartPrompt" class="commandprompt">Pick start point more text more</div>
					<div id="EndPrompt" class="hiddencommandprompt"><moi:Text textid="Line end point prompt"/></div>
				</flex>
				<div>
				</div>
			</hbox>
		</div>
		<moi:CheckButton id="bothsides"><moi:Text textid="Line both sides checkbox"/></moi:CheckButton>
		<moi:CommandCancel />
	</body>
</html>
10768.4 In reply to 10768.3
Thanks Michael
I'll do some experimenting.
10768.5 In reply to 10768.3
The first method to have a help "button" is OK.
The hbox and flex method is very nice.
Is there a text editor to create messages in an alert box?
In the past I have had to use /n for newline and + and '
Well, just using text, not variables, would not be too hard...
Sample code:
moi.ui.alert( 'x1 = ' + x1 + ' cm' + '\n' + 'dValue = ' + dValue + ' cm' + '\n' + 'x0 = ' + x0 + ' cm' );
10768.6 In reply to 10768.5
That's the main way to do it. Sometimes it can be good to build it up in smaller chunks like
str += '...';
str += '...';
But there is also a string formatter you can use like this:
var x1 = 5, dValue = 3, x0 = 8;
var msg = moi.ui.formatString( 'x1 = %1% cm\ndValue = %2% cm\nx0 = %3% cm', x1, dValue, x0 );
moi.ui.alert( msg );
So for that way you have one "template string" that contains placeholders %1% , %2%, etc.. which are replaced by the values passed after the format string.
That method reduces the amount of little fragments that the regular way uses.
Show messages: All  1  2-6
