Is there a shortcut, like Z, that restores the view to zup?
All  1  2-4
10767.2 In reply to 10767.1
Hi Simon, there is a view rotation mode that keeps z always up all the time.
That's under Options > View > Rotate/Pan/Zoom options > Rotation style = Rotate around world z axis.
If you like having Z pointing up then the usual way would be to have it set to "Rotation style = Rotate around world z axis" and not "Rotation style = Free rotation" which does not keep z pointing up.
If you want to have "Rotation style = Free rotation" and push a shortcut key like Z to set z-up occasionally then that's possible by setting this up on a shortcut key (Options > Shortcut keys):
script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.tiltAngle = 0;
10767.3 In reply to 10767.2
Thank you Michael.
Rotate round world z axis is good.
But the shortcut doesnt do anything. Not on my mac, anyway.
Simon.
10767.4 In reply to 10767.3
Hi Simon,
It is normal that it won't do anything if your view is already oriented with z upwards.
Maybe I have not understood what type of thing you're running into. Can you please post an example .3dm model file that has the view in the undesired position?
Show messages: All  1  2-4
