Change View Control
All  1  2
10766.2 In reply to 10766.1
Hi Tgoy, for the edit frame corners that appear around the selected objects, that can be modified in moi.ini under:
[View]
EditFrameOpacity=45
That can take a value between 0 (fully transparent) to 255 (fully opaque). You can edit the moi.ini file by going to Options dialog > General > "Edit .ini file" button.
In the v5 beta the view controls that are at the bottom of viewports has opacity controlled by the current UI theme. You can create a new theme and modify the value under Options > General > Manage themes > Viewport > "View controls opacity". That also takes a value from 0 to 255.
Show messages: All  1  2
