How to use Groups
All  1-5  6-9
10762.6 In reply to 10762.5
> Looks like there can be groups of groups...
Yup, groups can be contained inside other groups.
Basically one of the main jobs for groups is if you have a more complex model where you would be trying to manage a list of say 100 named objects for example, you can use groups to arrange related pieces together. You can then collapse some of the groups so that the names contained within the collapsed groups will not be displayed for the moment and so you can work in the scene browser with a shorter visible list.
If you only have a relatively small number of objects where having their names all shown in one single list isn't really a problem then you may not gain very much with using groups for that type of situation.
There are some other things that groups can be useful for like making a set of objects select as one unit to keep them together more easily but hiding some names temporarily is probably the most significant thing.
It seems strange, but the slideshare instructions from Donna and the nearly same ones from Simon, have an error.
All of the MidSpiral objects need to be shifted 3.75 cm to the left. (Or at least the Mid spiral.)
All of the 3rd portion of the spiral, the InnerSpiral, and related objects, need to be shifted 1.875 cm to the left. (Or at least the inner spiral.)
So that the 3 turns of the spiral can be joined, without gaps
So the second and third center boxes are not "concentric".
(They did mention that the spiral had to be aligned.)
Donna:
https://www.slideshare.net/ambasadonna/constructing-an-ionic-volute
Simon:
https://www.slideshare.net/ozi/drawing-an-ionic-volute
Using Orient line-line, make copies checked, the moved MidSpiral objects were selected, the MidSpiral start and end used as Orient source line,
and the start and end of the OuterSpiral were used for the Orient target line, resulting in the InnerSpiral objects being created. (50% scale.)
The Groups, and Group names, used as the Orient source were duplicated in the Objects and Groups display, but can be renamed Inner...
EDITED: 6 Jul 2022 by BEMFARMER
A quick thought before bed:
Dimensions can be placed in a Group, or Groups.
Example:
Group1, all dimensions for subassembly1.
Group1, ChildGroup1, Horizontal Dims.
Group1, ChildGroup2, Vertical Dims.
Group1, ChildGroup3, Angles.
etc...
Maybe laid out better?
Could some such outline of Dimension groups be pre-formatted?
Or it is easy to set it up from scratch...(?)
Currently, a Dimension can be quickly assigned to a Group or ChildGroup.
Select a dimension, and then click on the Group or Child group to assign it to.
A Dimension is a type of object, and behaves like geometric objects...
EDIT: Per Michael, Types can be used instead, see next post.
EDITED: 8 Jul 2022 by BEMFARMER
10762.9 In reply to 10762.8
> Example:
> etc...
It's certainly possible to do that, but if you want to access all dims of a particular type you can use the Types section of the Scene Browser to do that also, there are different sub types listed under Types > Annotations.
Show messages: All  1-5  6-9
