MoI versuon in display
All  1-4  5-12
10760.5 In reply to 10760.3
There are some times when I would like to just glance at a "corner", and see MoI4 or MoI5b on the screen, rather than clicking on help a couple times...
10760.6 In reply to 10760.1
Hi BLS, I've set up a script for you that will insert the MoI version number in the lower right corner of the side pane.
Put it in the startup folder inside the MoI appdata folder.
On Windows: %AppData%\Moi\startup
On Mac: ~/Library/Application Support/Moi/startup
EDITED: 5 Jul 2022 by MICHAEL GIBSON
10760.7 In reply to 10760.6
Works for v4, & v5b ☺
Could be run manually in v3...
Thank you Michael.
EDITED: 5 Jul 2022 by BEMFARMER
Cool! :)
Message 10760.9 deleted 5 Jul 2022 by BEMFARMER
10760.10 In reply to 10760.6
Many thanks Michael,
that is exact what i want to see!
Best regards
Bodo-Lutz
Do you think, this script will be a standard for the next versions ?
It's true, that we use often stable and beta versions on our machines.
Knowing which one has been launched is a good idea for next versions.
10760.12 In reply to 10760.11
Hi Phiro,
It should work in future versions too once it is installed in the MoI appdata startup folder.
Show messages: All  1-4  5-12
