ScaleArray not working properly
All  1  2-5
1076.2 In reply to 1076.1
Yes same problem result! I had must make a mistake ;)
Curious this script has working fine in the past ???
EDITED: 30 Oct 2007 by PILOU
hihi I have forgotten something :)
You must draw in your first objects a "single point" !!! Menu draw Curve / more /point
Select your objects + the single Point
Apply the Transform Array
Then Select all Object + Points (except the curve if you have made an Array Curve)
Alt + S and then all works fine :)
1076.4 In reply to 1076.3
Your tips work fine.
I have tried it.
I think I must save this tread for my documentation.
Thank`s Pilou.
Regards,
Lish
1076.5 In reply to 1076.4
Yes, ScaleArray depends on having that single point object included in the array. It uses that point as the origin point of the scale, otherwise it wouldn't know from what location to scale from.
Here is the original ScaleArray post, it has a screenshot example and some basic instructions: http://www.moi3d.com/forum/index.php?webtag=MOI&msg=275.109
Show messages: All  1  2-5
