Your workflow for texturing?
All  1-5  6-8
10759.6 In reply to 10759.1
Hi Nikita,
> How can I close that hole and how I can boolean the cylinders from the main object?
I've attached a version here that has the hole patched up. There is a little edge in there that is making things a bit difficult. I ended up untrimming the surface above the hole and retrimming it with a line that matched up to the little edge better, then i was able to join together the little edge with its longer neighbor and use Construct > Network to make a filling piece.
10759.7 In reply to 10759.5
Hi Nikita,
> I read sometimes that tris / n-gons are not so good for texturing and quads are better.
There are some programs that do not have very good support for n-gons. If that's the case then yes for that particular program this might be true but it's not applicable to programs that handle n-gons well.
10759.8 In reply to 10759.6
Thank you very much for having a look and fixing it and the explanation, even though I couldn't recreate the fix myself, but yeah I will just be more careful and thoughtful about every step I do in MoI to not come into issues like that later.
And also I found out some ways to align the texture to the exported MoI3D model in Octane. Thanks!
Show messages: All  1-5  6-8
