Your workflow for texturing?
All  1-3  4-8
10759.4 In reply to 10759.1
Hi Nikita,
> I also heard and read, that because of the "bad topology" from the MoI3d export
> it's difficult to create such things?
Where did you hear that? MoI's export is well known for its high quality mesh export because it creates an n-gon mesh with a clean wireframe that resembles the original CAD model instead of just a huge pile of triangles.
But to take advantage of it your render program will need to be robust in handling n-gons.
What it doesn't do is generate an "all quad" mesh topology that is ready for sub-d smoothing. That's a different type of mesh structure.
> What programs do you recommend? I use an old Cinema4D version, where the UV
> functions are very bad. Maybe Blender? Or something else?
Is your Cinema4D version like 20 years old or something?
For the numbers on a dial like that a decal or label type method like Ed mentions above is probably easiest, you don't need to use UV mapping for that.
If you did want to set up UV mapping, Blender would be worth trying. Export out from Moi to FBX format using n-gons for import into Blender.
10759.5 In reply to 10759.4
I read sometimes that tris / n-gons are not so good for texturing and quads are better. But yeah that's the thing, I don't know yet a lot about texturing. So I will try it out with the render engine.
And yes the export is very good in MoI. The model in C4D is exactly like the model in MoI with all the correct shading in most cases:)
10759.6 In reply to 10759.1
Hi Nikita,
> How can I close that hole and how I can boolean the cylinders from the main object?
I've attached a version here that has the hole patched up. There is a little edge in there that is making things a bit difficult. I ended up untrimming the surface above the hole and retrimming it with a line that matched up to the little edge better, then i was able to join together the little edge with its longer neighbor and use Construct > Network to make a filling piece.
10759.7 In reply to 10759.5
Hi Nikita,
There are some programs that do not have very good support for n-gons. If that's the case then yes for that particular program this might be true but it's not applicable to programs that handle n-gons well.
10759.8 In reply to 10759.6
Thank you very much for having a look and fixing it and the explanation, even though I couldn't recreate the fix myself, but yeah I will just be more careful and thoughtful about every step I do in MoI to not come into issues like that later.
And also I found out some ways to align the texture to the exported MoI3D model in Octane. Thanks!
Show messages: All  1-3  4-8
