A right click mistery callback
All  1  2-5
10757.2 In reply to 10757.1
Hi Gaston, do you mean the Dim palette in the side pane here? :
10757.3 In reply to 10757.2
Thanks MIchael,
No, it was In the side panel right above Draw_curve and Draw Solid palette .
If my recollection is right it looked something like this:
Dimension
(a list of parameters to set)
And it appeared after a right click.
But don't loose sleep over it.
Gaston
10757.4 In reply to 10757.3
Hi Gaston, when you are running a dimension command there will be some options displayed in that area, which looks like this:
And if you right click inside of a viewport it will launch the last used command again.
10757.5 In reply to 10757.4
I was wondering if there existed a list of the last commands sequence used somewhere.
My recollection must have failed me.
As I said do not loose sleep over it.
Thanks again,
Gaston
Show messages: All  1  2-5
