FLOW DEFORM SPIRAL
All  1-3  4-8
10755.4 In reply to 10755.3
> Can the MoI properties of tangents and derivatives, etc., of a curve be used to investigate the
> rotation frame(s) of the spiral target curve?
Not quite, the rotation of a sweep frame is another thing, look up "Bishop Frame" for references.
Bishop, R. L. "There is more than one way to frame a curve.",
American Mathematical Monthly (1975) pp. 245-251
The intrinsic "Frenet frame" of the curve formed by the tangent and curvature vectors does not work well using it for sweep frame rotation.
EDITED: 4 Jul 2022 by MICHAEL GIBSON
10755.5 In reply to 10755.3
> Using a center axis does not seem to make any difference to the Flow, as far as I can tell.
For me it does, I get the red result from the original setup, and the blue result from one
where I moved the base line to run down the center of the object:
10755.6 In reply to 10755.5
Thank you Michael.
(I added an edit to indicate that my statement was false, re non-center axis base curve.)
-Brian
(I have heard about Bishop frames. Will have to study Bishop frames for spiral... I guess Flow must use them internally.)
10755.7 In reply to 10755.6
Hi Brian, yes curve-to-curve Flow uses the Bishop frames that is also used by Sweep.
I would like to add a way to control the start normal on the base and the start normal on the target curve.
10755.8
Thanks Michael, Brian indeed the centreline is AOK I though I tried that early in the experiments cycle the ol keep it simple stupid method always wins.
Alex.
Show messages: All  1-3  4-8
