Can't get repeatable concentric pattern cut
All  1  2-9
10748.2 In reply to 10748.1
Hi Gunter,
I would guess it is backlash on your controller/motors.
There is a diagnosis method to run then enter backlash compensation into the control software to help...
10748.3 In reply to 10748.1
10748.4 In reply to 10748.1
10748.5 In reply to 10748.2
Thank you Burrman, they did ask me to do a test and that seems ok according to them
based on the picture of the cut I sent to them. Nothing much after that :(
10748.6 In reply to 10748.3
Brian, thank you so much for digging in to this. They did actually send me another
spindle but it seems to have just got worse!
I'll send them the Carbide forum links you sent me.
Thank you so much!
Gunter
10748.7 In reply to 10748.6
Pro version of Carbide Create has Engrave toolpath.
https://shop.carbide3d.com/products/mcetcher-diamond-cnc-drag-bit?variant=39271659634749
Quote from link:
Drag Bit Toolpaths
You have a couple of options to generate a toolpath for a drag engraver:
Use Carbide Create, or any other 2D CAM program, to generate contour toolpaths and pocket toolpaths with an RPM of zero (or leave your spindle turned off).
Use the Engrave toolpath in Carbide Create Pro to generate outline and fill toolpaths for drag engraving."
It is not really very relevant to MoI. ?
10748.8 In reply to 10748.7
Good day.
you might need to check how accurate your machine is and if it can produce repeatable results and go from there.
I do suggest that you perform these tests... this is an avid machine but the test can be applied to your machine as well.
https://www.youtube.com/watch?v=E5H7Fsrq95c
10748.9 In reply to 10748.8
That's a really great calibration set up! You're using Mach 4 in your set up .. I'm on GBRL.. I have to figure out how to count steps!
Thank you for your youtube link!
Gunter
Show messages: All  1  2-9
