Question about flow
All  1-3  4-9
10745.4
Flow with History...
10745.5
Thank you for answering Michael and Pilou! I really appreciate it!
Yes, the reference plain is not trimmed Michael, the points stay on the corners and if needed I add points. But if you want a cylinder to not be "squeezed" in one dimension you have to take a two step process adding a second perpendicular plane and running flow again, correct?
I am just trying to make sure I am not taking the "long way home" :D
10745.6 In reply to 10745.4
Woah, I really need to experiment with the history option, haven't tried it!
10745.7 In reply to 10745.5
Hi nameless,
Yes that's correct.
10745.8 In reply to 10745.7
Thanks a lot for all the help!
10745.9
Something I found interesting with Flow and history is that you can change colors of the target item then update the target and the geometry will update and leave the new color intact.
In the attached video I changed the strips on the corners, then edited the target and new colors remain updated.
EDITED: 4 Nov 2022 by SBEECH
Show messages: All  1-3  4-9
