Save custom CPlane(s)
All  1-3  4-10
10744.4 In reply to 10744.3
Hi MindSet,
Although I've not looked into writing the script, you might consider looking at the View Manager script https://moi3d.com/forum/index.php?webtag=MOI&msg=10028.31 as the basis for something to accomplish what you're asking for. Teddy took a unique approach to saving the additional information needed as a .views.json file, so not a global setting but unique to the file.
--Larry
10744.5 In reply to 10744.4
Thank you Larry,
Appreciate it Sir.
MindSet
10744.6 In reply to 10744.5
Hi MindSet,
Dusting off my earlier tinkering with setting a CPlane via a script, the only means that I'm aware of to create a CPlane is moi.view.setCPlaneInteractive() which, as its name implies, brings up the CPlane dialog. So, not really a means of creating a CPlane from some previously stored information. There may be other functions available, I'm just not aware of them.
--Larry
10744.7 In reply to 10744.6
Hi Larry, scripting interface for cplanes is as follows:
moi.view.setCPlane( Frame, ApplyToAllViews, OrientOrthoViews ); - takes a required coordinate frame parameter, optional boolean parameter for whether to apply to all views or 3d view only, and optional boolean parameter for whether to orient ortho views or keep them in world.
moi.view.getCPlane(); - returns coordinate frame for the active cplane.
moi.view.setCPlaneInteractive(); - runs the user interactive method for setting the cplane same as pushing the View > CPlane button.
moi.view.resetCPlane(); - sets the current cplane to world.
10744.8 In reply to 10744.6
In the Elastica2 and Clothoid scripts, pointpicker is used to get cplane.
I think that this is true.
From Michael's help from 2013.
var pointpicker = moi.ui.createPointPicker();
if ( !GetPoint( pointpicker ) ) return;
var cplane = pointpicker.ptframe;
10744.9 In reply to 10744.4
Thanks Larry,
It's still a challenge because the script stores views but not CPlane(s).
I tried to store data from "moi.view.getCPlane();" into the Jason file, but I don't know its properties nor how to work with them to restore it from the subsequently retrieved data.
It would be nice if we could store CPlanes as construction planes (unprintable..? objects) within the .3dm file!
Any hints, anyone?
- Mindset
10744.10 In reply to 10744.9
Hi Mindset,
The return from moi.view.getCPlane() is a coordinate frame object, it has properties for: .origin, .xaxis, .yaxis, and .zaxis , and each of those points and vectors have properties for .x .y and .z .
When you want to make a coordinate frame object, you call moi.vectorMath.createFrame() and on the coordinate frame you can set it using the .set() method which takes 9 values: frame.set( originx, originy, originz, xaxisx, xaxisy, xaxisz, yaxisx, yaxisy, yaxisz ); - the z axis is automatically calculated from the x and y axes and isn't set by itself.
Show messages: All  1-3  4-10
