Adding curvature
All  1  2-11
You have a long thread about guitar neck here! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=8883.1
PS you can use the search engine of the forum! ;)
https://moi3d.com/forum/discussion.php?webtag=MOI&right=search
10735.3 In reply to 10735.1
Hi John, if you have a .3dm file with your current "unbent" geometry if you could post that it would help to better understand your question.
You might check here for some guitar tutorials:
https://3dcncguitars.com/
10735.4
Here's what I'm working on
Thanks guys
10735.5
sorry this is the area that needs that volute work
10735.6 In reply to 10735.1
Hi John, thanks for posting the model that helped me understand your question a lot better.
But it's pretty difficult for MoI's deformation tools to warp only a localized area of a shape, especially with a feature line that is not straight.
If you were doing it in sub-d it would be pretty easy to directly manipulate the edges.
To do it by CAD construction, it might be something like this, a sweep and an extrusion that intersect each other. But there is still some pretty difficult area to fill in:
10735.7 In reply to 10735.6
And it may help to generate some more material on the sweep by extending the shape down like this:
10735.8 In reply to 10735.7
Maybe then cut off the end of the sweep using Trim and put in a blend surface:
-Michael
EDITED: 20 Jun 2022 by MICHAEL GIBSON
10735.9 In reply to 10735.8
Or maybe that last piece could be a sharp corner and then fillet it.
But overall shaping of the extended sweep with sliced off end seems pretty good:
10735.10
Michael
thank you this is a huge help your the best
John
10735.11 In reply to 10735.9
That is so cool!
Show messages: All  1  2-11
