Orientation of subd nurbs import
All  1-2  3-4
10728.3
It's from Rocket 3f, or topogun. Just a retopo surface I'm bringing in to get a CAD surface from it. I'll check out the command thanks
10728.4 In reply to 10728.3
Hi Chris,
Do either of these have any options for the exporter for what orientation to use for generating the .obj file?
Previously you wrote:
> I've tried the y/z up in the options but this doesn't change it
Were you referring here to the option in MoI under Options > OBJ options ? Those options apply only to OBJ exporting out from MoI. They don't affect SubD import conversion.
But you might be able to find similar options in Rocket3f or topogun, look for import/export options in those apps.
But it's pretty straightforward to fix it using Transform > Orient > View/view , you just click once in the front viewport and once in the top viewport and it will remap the selected objects.
Show messages: All  1-2  3-4
