Delete point in polyline
10726.1
Hi all,
I feel like I'm going crazy -- is it not possible to delete a point in a polyline? I'm able to do it on additionally-added points to that line, but not on the original points.
In Illustrator for example you can use the Delete Anchor Point Tool to remove points. Illustrator changes the curve to reflect the lack of that point.
Is it possible to do something similar in Moi3D? Sorry if this is the most obvious question ever.
Size: 23.4 KB, Downloaded: 17 times, Dimensions: 709x642px
Size: 21.9 KB, Downloaded: 19 times, Dimensions: 705x610px
10726.2 In reply to 10726.1
You mean this ?
If yes Just Edit / Show Points / select your points kill wished and press key Delete or the Red X bottom screen on the left...
10726.3 In reply to 10726.2
Hi Frenchy, thanks for the reply.
Yes exactly like that!
I've just worked out what I was doing wrong: I had to deselect the line before reselecting the point to be deleted. Newbie mistake to the max. I was showing points on the line, and directly clicking on the point to be deleted. While that point displays as the only one selected, the whole line is still actively selected, so it all gets deleted.
Thanks again for the help.
-T
10726.4 In reply to 10726.3
No problem!
Have fun discovery!
10726.5 In reply to 10726.4
Thanks!:)
