Array along curve problem
All  1-6  7-13
VClone is working fine!
But the Vseed has a glitch! :(
Does the same for you ?
Seems working in the V3 !
But not sure that will for the asked problem because vectors are perpendicular to the surface!
EDITED: 15 Jun 2022 by PILOU
But i found an elegant solution :)
The Multi Iso+! ;)
Then apply the VClone! ;) (if i refind how works exactly the VClone function! :)
Ok refound again the Vclone use ! :)
You must play with axis gizmo for the good one orientation and placement result!
Here i am on the external surface of the cylinder (for better see the axes )
you must take of course the internal axis depending of the result whished!
Good luck! :)
Ps you have a possibility of History inside the plugin itself if wanted!
Enable or disable Scale / Vectors and some variations also!
A very versatile cool one!
10725.10 In reply to 10725.6
Hey Barry,
I feel like I want to move in and live in that result for some reason.
Pretty cool!
10725.11 In reply to 10725.9
I've not used the Vclone script before thanks for the demo.
Barry
10725.12 In reply to 10725.11
Hi Barry, I've tuned up Array along curve with the "Align to surface' option for the next v5 beta. It should avoid excess twisting around the surface normal.
10725.13 In reply to 10725.12
thanks that's great.
Barry
Show messages: All  1-6  7-13
