Bulbous ring question
All  1-7  8-9
It's a tuning and not so fast process...
I cuted the top of the ring to have a bigger base. Next, I deleted the top face.
With your bezel I took its base to have the octogonal curve.
On this curve I made a ReconstructCurve (10 or 12 points if I remember) to have a seamless curve.
With this curve I do a plane with the "Planar" function. I do it the use later the blend function.
Because of the initial Process used to do the ring, the top of the ring have 4 edges.
So I cuted the edge of the top planar to have 4 edges too.
To do this I used the trimming function (I used trim points to do it)
Now with 4 edges on the top of ring and 4 edges on the planar, I use the Blend function to have the 4 surfaces.
This gives us a soft transition between the planar and ring.
Join all and your ring become a solid...
You can next tune the size and the place of the bezel and the stone to have something as you wanted.
Have a nice day and fun modeling...
10724.9 In reply to 10724.8
Hi Phiro,
Thank you so much for the explanation and for all that work, that's very kind of you. :)
Gunter
Show messages: All  1-7  8-9
