C API, Scripting Interface, Python, Other Langs
 1-16  17-30
Hey Brian,
Yeah, i discovered that here too. Michael had fixed it.
I also like the idea of moving it to the appdata directory!
So i will make the changes to my sidepane code, and when i am sure i have done it correctly, i will update my original post code example, so i don't lead anybody astray....
If you have already created that line properly, maybe put it here so i can copy and paste it???
[EDIT: I have changed my original post here to fix "code" error]
EDITED: 8 Jun 2022 by BURRMAN
10720.18 In reply to 10720.8
"""""""Some newer factories have documentation by Michael on the forum.
e.g. Network.
offset factory has more details from Michael on the forum, than D Morrill's API."""""""""
Yes. This doc is fairly old. It was derived from the old IDL file MoI had with it.
Alot has changed since then. But this doc is a great ""overview" so to speak. It has to be used with that understanding...
10720.19 In reply to 10720.17
Hi Burr,
Your MoI4 sidepane modification is just right.
Note to others: The change is located at line 143 +/- of MoI4 sidepane.htm file, replacing pre-existing spaceholders td and /td.
Below History, as per Burr.
Windows 10 or 11, MoI4 files located below program files directory.
The moi_ref file now located in appdata directory.
For my version, I changed the name of the flask Icon from dmorrill.png to API_Icon.png, and the flask command button name from JavaScript ref to API ref. spacesaving
Totally unnecessary changes. Burr's code is just fine.
EDITED: 8 Jun 2022 by BEMFARMER
Burr's API modification works fine in MoI 5 beta, May 22, 2022.
It took about 2 minutes to copy the Icon, and modify the MoI 5 beta sidepane htm file (line 143 in notepad++).
AppData was already set up for the mod.
I wonder what sort of editor was used by D Morrill to create the API?
10720.21 In reply to 10720.20
@Jeff - No worries. You're welcome
Brian,
David explained he wrote a script which extracted the data from the IDL (Then hand supplemented it to be more robust). My guess is he was such a heavy programmer, he just wrote it to do a "toc" setup with jQuery at some level to create the page. Whether he did it with the UI stuff or just all code, is unknown.
To be clear, this is all Davids work. I just grabbed it for local consumption back when he created it.
Because his site is defunct and Max's mirror has been taken from us, I shared it here.
Frenchy should copy the file and document this on his weebly also!!!
10720.22 In reply to 10720.21
All that is very complex for me! :)
In any case I change the Max Links and put this API (Burrman) again in case of! :)
In a very rustic way before remake all your elaborate refinements!
+Moi's IDL (there no date on top page ? so this idl is for what version of MOI ?
https://moiscript.weebly.com/api-de-moi.html
And i must edit also the page of the French wiki...some headaches in perspective! :)
EDITED: 8 Jun 2022 by PILOU
10720.23 In reply to 10720.22
Hi Frenchy,
I wouldn't edit all your existing stuff.
Lets stay hopeful that Max returns!
This is the "offline version" from max's mirror. The original discussion was Brian and Max back when Max mirrored Davids docs....
So just a link to the post with an "offline version" tag, can help anyone that wants it...
10720.24
Hello All,
I have utterly unrelated question, so I apologize in advance!
Who was David C Morrill? And what happened to him?
Also I heard Max is back (but I cannot confirm it) is this info correct?
and a question for @Michael ;
With your help Sir; I shifted "Objects", "Types" and "Styles" tabs to the left side Is it possible for me to have Burr's Snapshot of David C Morrill there?
I am asking in advance before messing things up!
- Psygorn
10720.25 In reply to 10720.24
Drillbit,
The DMorrill documentation is a little outdated and was generated back in v3
Peer Pressure has worked on updating it and may be a better ref for you to add and use…
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=10857.1
10720.26 In reply to 10720.24
Hi Psygorn,
Do you mean having David Morrill's script documentation embedded in a pane inside the program UI?
If so then I wouldn't recommend that - I don't think the documentation has been formatted with the intention to be read in a narrow pane, it's better to view it in a separate web browser window.
10720.27 In reply to 10720.24
I have Google searched for him several times in the last few years, without any non-old results, so one can draw his own conclusion probabilities. There are, or were, half a dozen people in the US with said name. Maybe there is a former associate with info?
10720.28 In reply to 10720.27
i believe, this could be him/his work. same look&feel as that MoI api documentation...plus rather complex and thought-out.
http://tvsoftball.duckdns.org:8888/
http://tvsoftball.duckdns.org:8888/document/TVSIS%20Score%20Users%20Guide.pdf
i guess he somewhat retired and moved to the villages...
https://www.linkedin.com/in/dmorrill
10720.29 In reply to 10720.27
So he really walked into the sunset!
10720.30 In reply to 10720.26
Ok, I won't do that!
-Psygorn
Show messages:  1-16  17-30
