Confused about merge command
10716.1
Hi all,
When I construct a profile from multiple joined segments and extrude it, the resulting solid shows lines where the various segments meet.
I thought I might be able to use the merge command to merge the multiple segments into a single curve before extruding but it doesn't seem to do anything. The join command joins the line segments together but the extruded object has the lines showing. Am I misunderstanding the merge command and if so, is there any way of achieving a line free solid please?
Thanks!
Dave
Size: 22.8 KB, Downloaded: 61 times, Dimensions: 1321x365px
Size: 226.4 KB, Downloaded: 55 times, Dimensions: 1511x614px
Size: 51.3 KB, Downloaded: 50 times, Dimensions: 1872x465px
10716.2 In reply to 10716.1
Hi Dave, on areas where the curve segments are tangent smooth to each other the Merge command in v5 will combine those together into longer single segments that will then generate larger faces when extruded. You'll need to use the v5 beta for that to work, and join the curve together before running merge. You select a joined curve for that case.
For areas that are not smooth then it is normal that those will not be merged together, when you have sharp corners those will form separate faces at that crease point. So you have to remove the sharp corner in the curve's shape to combine those cases, you can delete the control point at the juncture or use fillet or cut out some open area and put in a blend.
If you are still having trouble please post the .3dm file with your curves in it so I can test with it.
10716.3 In reply to 10716.2
I can't tell you how happy I am with the version 5 fix Michael, you're a total star. It just works so well now.
Thank you!
