xNURBS Rhino plugin
All  1-6  7-8
10714.7 In reply to 10714.6
Hi pafurijaz, usually the best way to create surfaces without seams is to make areas that should be smooth to be made out of one larger extended surface instead of filling things in "patch by patch".
The "patch by patch" method is a much more difficult approach and tends to be very finicky even with fancy surfacing tools.
10714.8 In reply to 10714.7
Thanks , for advice, i will consider in the my workflow, in fact i use often patches to create surfaces,
Greetings
Show messages: All  1-6  7-8
