xNURBS Rhino plugin
All  1-5  6-8
10714.6
Hi Michael, I understand that it is not easy, however I continue to hope that in the future you can add tools on the control of nurbs patches on degrees and spans, I will try to refine my workflow with Moi3D in order to be able to create surfaces without seams, with a bit of effort I think it can be done, but some tools, such as reflection maps with zebra, could give a lot of help on this, I hope you can find the time and some valid solution.
@Pilou, yeah this plug-in can simplify a lot the effort to make surfaces continuity in a complex scenario, this make Rhinoceros a valid tool for advanced surfacing.
Greetings.
10714.7 In reply to 10714.6
Hi pafurijaz, usually the best way to create surfaces without seams is to make areas that should be smooth to be made out of one larger extended surface instead of filling things in "patch by patch".
The "patch by patch" method is a much more difficult approach and tends to be very finicky even with fancy surfacing tools.
10714.8 In reply to 10714.7
Thanks , for advice, i will consider in the my workflow, in fact i use often patches to create surfaces,
Greetings
Show messages: All  1-5  6-8
