Save as screen > jpg
All  1-4  5-13
10713.5 In reply to 10713.2
Its the script to save the UI as screenshot which saves
as png as default and I would like to change the
default to jpg
10713.6 In reply to 10713.5
Hi Tom,
> default to jpg
Can you please post the script code?
10713.7 In reply to 10713.6
Of course, sorry I assumed you had it in your archive.
// config: norepeat
moi.geometryDatabase.saveAs( moi.command.getCommandLineParams() );
script:var img = moi.view.screenshot( 'viewpanel', false ); var filename = moi.geometryDatabase.currentFileName; if ( filename != '' ) { img.save( filename.substring(0,filename.length-3) + 'jpg' ); }
10713.8 In reply to 10713.7
Hi Tom,
Well there are quite a few different variants.
The one you posted does not seem to match your first description though, it's doing a "SaveAs" and then in addition to saving the model it's writing out a screenshot image as a .jpg file with the same base name as the .3dm file. I don't see where it is asking you for a PNG filename.
Is that maybe not the right one?
10713.9 In reply to 10713.8
I were not sure about its name so I must have choosen the wrong one ...
I copied the following lines directly out of the option menu where I assigned
it to the keybord "y" so
script:var img = moi.view.screenshot( 'viewpanel', false ); var name = img.getSaveFileName(); if ( name != '' ) img.save( name
10713.10 In reply to 10713.9
Hi Tom, try putting this in instead, this one should put up a file dialog that only has .jpg in it:
script:var img = moi.view.screenshot( 'viewpanel', false ); var name = moi.filesystem.getSaveFileName( 'Save Image', 'JPG files (*.jpg)|*.jpg' ); if ( name != '' ) img.save( name );
10713.11 In reply to 10713.10
That win one click against the multiple choice! :)
And less versatile! :)
10713.12 In reply to 10713.11
Two clicks ;-) It may sound exagerated to try to save one or two clicks.
But if you do that consistently everywhere it makes working so much more
fun. I enjoy MOI so much because its workflow is so smooth that it is
almost like a direct translation of thought into shape.
Without having to stmble about annoying clicks ;-)
10713.13 In reply to 10713.10
I appreciate your help Michael - thank you vry much !!
Show messages: All  1-4  5-13
