Save as screen > jpg
All  1-3  4-13
10713.4
Hey Pilou thank you very much.
being a workfolw gourmt I want to save two clicks
and save directly as jep instead of opening the menu ...
10713.5 In reply to 10713.2
Its the script to save the UI as screenshot which saves
as png as default and I would like to change the
default to jpg
10713.6 In reply to 10713.5
Hi Tom,
> default to jpg
Can you please post the script code?
10713.7 In reply to 10713.6
Of course, sorry I assumed you had it in your archive.
// config: norepeat
moi.geometryDatabase.saveAs( moi.command.getCommandLineParams() );
script:var img = moi.view.screenshot( 'viewpanel', false ); var filename = moi.geometryDatabase.currentFileName; if ( filename != '' ) { img.save( filename.substring(0,filename.length-3) + 'jpg' ); }
10713.8 In reply to 10713.7
Hi Tom,
Well there are quite a few different variants.
The one you posted does not seem to match your first description though, it's doing a "SaveAs" and then in addition to saving the model it's writing out a screenshot image as a .jpg file with the same base name as the .3dm file. I don't see where it is asking you for a PNG filename.
Is that maybe not the right one?
10713.9 In reply to 10713.8
I were not sure about its name so I must have choosen the wrong one ...
I copied the following lines directly out of the option menu where I assigned
it to the keybord "y" so
script:var img = moi.view.screenshot( 'viewpanel', false ); var name = img.getSaveFileName(); if ( name != '' ) img.save( name
10713.10 In reply to 10713.9
Hi Tom, try putting this in instead, this one should put up a file dialog that only has .jpg in it:
script:var img = moi.view.screenshot( 'viewpanel', false ); var name = moi.filesystem.getSaveFileName( 'Save Image', 'JPG files (*.jpg)|*.jpg' ); if ( name != '' ) img.save( name );
10713.11 In reply to 10713.10
That win one click against the multiple choice! :)
And less versatile! :)
10713.12 In reply to 10713.11
Two clicks ;-) It may sound exagerated to try to save one or two clicks.
But if you do that consistently everywhere it makes working so much more
fun. I enjoy MOI so much because its workflow is so smooth that it is
almost like a direct translation of thought into shape.
Without having to stmble about annoying clicks ;-)
10713.13 In reply to 10713.10
I appreciate your help Michael - thank you vry much !!
Show messages: All  1-3  4-13
