Dimensions Font Scaling
All  1-5  6-9
10712.6 In reply to 10712.5
Thank you very much Michael.
I like the looks of the Dim Text as Label. (Annotation object)
I was thinking of creating an array of Plane rectangles, and setting the Style of each, sequentially, according to all of the current Styles, and placing the Style Name as a text Label to the side.
(The Dim Text size will match the size of the Style rectangle.)
I think that I have all of the code bits to do this. (More or less anyway.)
I am up to 72 Styles, which is perhaps a bit too much.
So I need to delete some that are too Yellow, or too similar to others in color.
Maybe I should arrange them according to the main color hues: Red, Orange, Yellow, Green, Blue, Violet, Brown, Black, Grey, and White?
10712.7 In reply to 10712.5
for me it makes no sense to save a dimension-preset in a project file. It is possible to save it as a global preset, so that it is always available without having to open a specific file. It would also be nice if you could simply copy and paste the properties.
Maybe it would be possible to create a template file that contains the presets and is available in each file?
So far it's a bit awkward and rigid.
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;)
10712.8 In reply to 10712.7
Hi pixelhouse, yes you can do that with a template file.
Save a .3dm file with the property presets how you want them and then set that .3dm file as the startup template file under Options > General > "Template file".
Then the dimension presets from that file will be there when you start up MoI or do a File > New.
10712.9 In reply to 10712.8
Thank you Michael,
thats sounds good! I never have try to work with a startup file.
Jörg
Show messages: All  1-5  6-9
