Dimensions Font Scaling
All  1-4  5-9
10712.5 In reply to 10712.4
Hi Brian, documentation for Dimensions is here:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#Dim
Some info for how presets work is in there:
quote:
Annotation presets control the property values that will be applied to a newly drawn dimension. Presets are created and edited in the Options dialog > Dimensions section. Different presets can be created to make different styles and when you are drawing a dimension there is an option for which property preset to use. The "Default" preset is stored in the moi.ini file and so is globally available in all projects. Additional presets are project specific and saved in .3dm files .
> Would creating a new Preset cause the second Dim Text entry to match the first one?
Creating a new preset doesn't affect any already created dims, the presets control what properties to apply to a newly created dimension object.
> Does the regular old Text command create more or less the same text as the Dim Text?
Well the old Text command under Draw Solid > Text creates text as curve, surface, or solid objects in Moi. You can then use that text in part of a model like use booleans to cut an object with the text.
The Dim > Text creates an annotation text object in MoI. It can't be used as model geometry like you can't boolean with it but it works better as a label.
10712.6 In reply to 10712.5
Thank you very much Michael.
I like the looks of the Dim Text as Label. (Annotation object)
I was thinking of creating an array of Plane rectangles, and setting the Style of each, sequentially, according to all of the current Styles, and placing the Style Name as a text Label to the side.
(The Dim Text size will match the size of the Style rectangle.)
I think that I have all of the code bits to do this. (More or less anyway.)
I am up to 72 Styles, which is perhaps a bit too much.
So I need to delete some that are too Yellow, or too similar to others in color.
Maybe I should arrange them according to the main color hues: Red, Orange, Yellow, Green, Blue, Violet, Brown, Black, Grey, and White?
10712.7 In reply to 10712.5
for me it makes no sense to save a dimension-preset in a project file. It is possible to save it as a global preset, so that it is always available without having to open a specific file. It would also be nice if you could simply copy and paste the properties.
Maybe it would be possible to create a template file that contains the presets and is available in each file?
So far it's a bit awkward and rigid.
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;)
10712.8 In reply to 10712.7
Hi pixelhouse, yes you can do that with a template file.
Save a .3dm file with the property presets how you want them and then set that .3dm file as the startup template file under Options > General > "Template file".
Then the dimension presets from that file will be there when you start up MoI or do a File > New.
10712.9 In reply to 10712.8
Thank you Michael,
thats sounds good! I never have try to work with a startup file.
Jörg
Show messages: All  1-4  5-9
