Dimensions Font Scaling
All  1-2  3-9
10712.3 In reply to 10712.2
Hey Michael,
Thank you very much for kindly taking the time to read my message. I knew there would be a simple solution! That's awesome Michael and I'm grateful that you preempted this feature request! ;)
Have a great afternoon!
Tim
A few more questions about Text in the Dimensions menu please.
Where is the documentation for Dimensions?
Dim>Text brings up Text options box, with Preset: Default.
Is there somewhere to define more Presets?
The desired Preset would define Font Size as 16,
Scaling: By Model Units,
Height: 0.25 units
The Open Sans font is nice.
Select a created Dim Text, and press Details shows the Object properties.
But entering a second Dim Text reverts to the default settings, as far as I know.
Would creating a new Preset cause the second Dim Text entry to match the first one?
Does the regular old Text command create more or less the same text as the Dim Text?
I could do a little more searching the MoI setups for the answers...
In the Moi ui folder:
I see DimPreset.js (But it is in MoI4 ui folder already...)
I see the AddPreset.htm and AddTheme.htm (Where is the AddPreset button?
I found the Property preset: add preset under Options > Dimensions...
Can the Font Size be set for MyTestPreset property ? Without disturbing UI Font setting? ???
(Looks like yes:-)
Works great!
Thank You
EDITED: 13 Dec 2022 by BEMFARMER
10712.5 In reply to 10712.4
Hi Brian, documentation for Dimensions is here:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#Dim
Some info for how presets work is in there:
quote:
Annotation presets control the property values that will be applied to a newly drawn dimension. Presets are created and edited in the Options dialog > Dimensions section. Different presets can be created to make different styles and when you are drawing a dimension there is an option for which property preset to use. The "Default" preset is stored in the moi.ini file and so is globally available in all projects. Additional presets are project specific and saved in .3dm files .
Creating a new preset doesn't affect any already created dims, the presets control what properties to apply to a newly created dimension object.
Well the old Text command under Draw Solid > Text creates text as curve, surface, or solid objects in Moi. You can then use that text in part of a model like use booleans to cut an object with the text.
The Dim > Text creates an annotation text object in MoI. It can't be used as model geometry like you can't boolean with it but it works better as a label.
10712.6 In reply to 10712.5
Thank you very much Michael.
I like the looks of the Dim Text as Label. (Annotation object)
I was thinking of creating an array of Plane rectangles, and setting the Style of each, sequentially, according to all of the current Styles, and placing the Style Name as a text Label to the side.
(The Dim Text size will match the size of the Style rectangle.)
I think that I have all of the code bits to do this. (More or less anyway.)
I am up to 72 Styles, which is perhaps a bit too much.
So I need to delete some that are too Yellow, or too similar to others in color.
Maybe I should arrange them according to the main color hues: Red, Orange, Yellow, Green, Blue, Violet, Brown, Black, Grey, and White?
10712.7 In reply to 10712.5
for me it makes no sense to save a dimension-preset in a project file. It is possible to save it as a global preset, so that it is always available without having to open a specific file. It would also be nice if you could simply copy and paste the properties.
Maybe it would be possible to create a template file that contains the presets and is available in each file?
So far it's a bit awkward and rigid.
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;)
10712.8 In reply to 10712.7
Hi pixelhouse, yes you can do that with a template file.
Save a .3dm file with the property presets how you want them and then set that .3dm file as the startup template file under Options > General > "Template file".
Then the dimension presets from that file will be there when you start up MoI or do a File > New.
10712.9 In reply to 10712.8
Thank you Michael,
thats sounds good! I never have try to work with a startup file.
Jörg
Show messages: All  1-2  3-9
