Refraction script idea
All  1  2-6
10709.2 In reply to 10709.1
Following, the script could work as follows:
1. Extend refraction line to transition surface-or-line
2. If extended successfully, proceed
3. Get normal from transition surface-or-line
4. Create new line to refract
5. Scale sine of that line to the normal by refraction transition index (typed).
6. Mirror that line along transition surface and normal
I don't know how to write scripts for MoI, so someone maybe wants to do it.
EDITED: 30 May 2022 by FUBAX
10709.3 In reply to 10709.2
I believe that James can do that with Elephant without not so difficulties! ;)
10709.4 In reply to 10709.1
Hi Fubax, the node editor might be an easier place to start if you haven't done any script programming before at all:
https://moi3d.com/wiki/nodeeditor
10709.5 In reply to 10709.4
Hello, I can try the nodeeditor, thank you for suggesting that.
This is the equation I came up with for producing refracted line
And here's the GLSL code that could do just that, I need to look into MoI scripting.
GLSL code:
vec3 refract(float n_trans, vec3 incident, vec3 normal)
	// Scale normal (assuming normal is an unit vector)
	normal *= dot(incident, normal);
	// Preserve incident vector length as squared value
	float sq_length = dot(incident, incident);
	// Scale incident vector tangentially to normal,
	// by transition refraction index (eg. air/glass=1/1.52)
	incident = n_trans*(incident-normal)+normal;
	// Normalize length of refracted incident, to scale along sine
	return -incident*rsqrt(dot(incident, incident)/sq_length);
Maybe someone could implement that.
EDITED: 1 Jun 2022 by FUBAX
10709.6 In reply to 10709.5
It would be useful also if the node respected law of reflection. It means to have point/flat light source (solid) with rays (curves) as an input and curved surface - reflector (rotate conic curve) with Rho as a variable. Rays impacted of surface would be reflected to the detector (plane) in specific distance. This would be very nice educative tool. 2D would be enough :-)
Mik
Show messages: All  1  2-6
