V5 beta May-22-2022 available now
 1-11  …  52-71  72-91  92-111  112-131  132-145
10706.92
I'd love to see a "Max Fillet" or Max Chamfer" command, where when you highlight an edge MOI automatically tells you the maximum fillet or chamfer that it can apply to said edge. It would save a lot of time with experimenting since you'd know how far you could take the fillet or chamfer already.
Thank you for listening!
Robert
10706.93 In reply to 10706.92
Hi Robert,
Unfortunately it's very difficult to calculate such a value. It's hard to say for sure but it could be on the order of several years of work to accomplish that.
10706.94
Hello, Michael.
When we model with custom CPlane, wouldn't it be better if the 3D view has the 'up' direction as the sky like in the default CPlane? It doesn't work that way for the moment.
Please pardon my English, but I hope you know what I mean. Thank you very much.
10706.95 In reply to 10706.94
Hi Fortian,
Yes I'll see about putting in an option for that.
I noticed that the radial dimension places a + symbol (crosscheck?), at the center of the arc/circle.
Selecting the + symbol, with mouse drag from right to left, selects the entire radial dimension.
Normal behavior.
ps The MoI Dimensions show up in Rhino7. (very limited testing.)
EDITED: 28 Nov 2022 by BEMFARMER
10706.97 In reply to 10706.96
> Normal behavior.
Yes, when you select with a drag from right to left, objects that have any portion
inside the window will be targeted. The + symbol at the center of the circle or arc is part of the
radial dimension.
Yes, they should be seen with Rhino.
10706.98
I've setup MoI v5 with a modified Dark theme which is great for my eyes but can't seem to find a setting in the Theme Manager or MoI.ini file to change the color of the Selection Rectangle, which is black (dark) by default.
Could you tell me where I might find this setting?
10706.99 In reply to 10706.98
Hi danperk,
Sorry, there is not currently a setting for that. I will see about adding one though.
EDIT: actually this was a mistake, there is a theme setting for this, see below.
EDITED: 29 Nov 2022 by MICHAEL GIBSON
10706.100 In reply to 10706.99
Thanks Michael!
10706.101 In reply to 10706.98
Hi danperk, so actually there is a theme setting that you can use to modify the drag rectangle color.
There isn't a control for it in the theme editor editor UI but you can modify it by changing the theme colors directly.
To do that in the theme dialog (Options > General > "Manage themes") click the "Open themes folder" button and inside your theme's folder edit the defines.inc file in a text editor.
Inside the defines.inc file, the setting you need to modify is this one:
LINE_UNSELECTED_COLOR #000000
10706.102
Worked perfectly, Thanks Michael!
10706.103 In reply to 10706.101
Setting the color to #ffffff, (White) seems like a good choice to me, for the Dark theme.
Earlier today I switched from BrianDark theme to Default theme. (MoI5beta)
A couple of hours later, the Default theme had the Objects, Types, and Styles dropdown menu's in Dark theme.
Switching back to BrianDark, and the 3 dropdown menu's were in Default theme.
Same result with a couple more switches.
Then I switched to terminal green, and back to Default, and the menu's were correct theme colors.
Switched to Dark, and the menu's colors were also correct.
Now I switched to terminal green, and the menu's were Dark. (>>>With the Style dropdown menu open during the change<<<)
Switched to Dark, and the menu's are green.
Switched to Default, and the menu's are green.
Switched to Dark, and the menu's are Default color...
To sum it up,
If the Style dropdown menu is open (or one of the two other dropdown menu's is open), when the Theme is changed, the new Theme had the previous theme for the 3 dropdown menu's.
10706.105 In reply to 10706.104
Hi Brian, thanks for reporting this bug, I think it's fixed up for the next release.
In the meantime if you see the scene browser not updating to the current theme you can exit MoI and restart it and that should fix it.
Thanks, - Michael
10706.106 In reply to 10706.105
Cool.
Later today I want to check out the style of Leaders, and relation, if any, to presets.
Coordinates script had silver leaders?
Probably nothing...
10706.107
Hello Michael,
in MOI3D I get an artifact when I join two surfaces to make a solid in C-plane mode (otherwise (I mean in default coordinates) I don't get those artifacts) Could it be a bug? I checked both MOI V5 and V4 they both behave the same!
Best,
Psygorn
10706.108 In reply to 10706.107
Hi Psygorn,
It might be, can you please send me the file with the 2 surfaces in them before joining?
You can post it as an attachment here, or e-mail it to me at moi@moi3d.com .
Thanks, - Michael
10706.109 In reply to 10706.108
Sure!
I will send the file here!
Edit: Dear Michael I forgot to mention that there is a nasty curve close to the base of the surface, and I think that curvature is responsible for the artifact However, this happens in C-plane mode not default mode!
I have opened your file and separate the surface to see how surfaces are made with Show Pts.
The problem seems to be in top of the surface with messy concentrated points.
Size of this group of points is 0.02 x 0.00 x 0.09.
Perhaps reconstruct your surfaces will fix the problem.
Have fun
10706.111 In reply to 10706.109
Hi Psygorn, thanks for sending the file. Over here if I reset the cplane back to default and then mirror and join in the Front view I seem to get the same artifact.
Are you picking the mirror line in some other viewport to get the different behavior?
I think the root of the problem is it kind of folds back on itself in this area here:
Thanks, - MIchael
Show messages:  1-11  …  32-51  52-71  72-91  92-111  112-131  132-145
