V5 beta May-22-2022 available now
 1  2-21  22-41  42-61  …  142-145
Cool :)
French version in no time if necessary! :)
PS the flickering display of the SUBD Max Smirnov editor is resolved! Bravo!
EDITED: 22 May 2022 by PILOU
10706.4 In reply to 10706.3
Thanks Pilou! - Michael
Re tested the free Rocket 3F and its bridge to Moi3D
Works like a charm with the new V5 with "subdivided" object or not!
In the 2 ways! Rocket 3F <--> Moi3D
A cool alternative of the Blender one who is maybe not so easy! :)
10706.6 In reply to 10706.1
Looks like the Chamfer regression bug has been fixed.
Thanks!
10706.7 In reply to 10706.6
Hi RD,
Yep, that turned out to be from a change in v4 to have chamfer make analytic plane surfaces for chamfer surfaces when possible and that uncovered a bug in analytic plane/plane surface intersection that is now fixed.
10706.8 In reply to 10706.7
Wonderful. Thanks for taking the time to fix the issue. Looking forward to the V5 release version!
Finally added release notes for this build. - Michael
10706.10 In reply to 10706.9
Cool!
The French version is here
https://moiscript.weebly.com/nouveauteacutes-v5.html
PS you don't speak about the flikering of the Max SMirnov Subdive functions! ;)
10706.11 In reply to 10706.10
Yes, sometimes it's a bit difficult to make a simple description of a change. Sometimes I leave out a few things if they were like that especially if I've already told the person who reported it that there is a fix prepared for the next release.
10706.12 In reply to 10706.11
No problem! :)
10706.13
Michael,
There is a minor problem with both beta releases, in that the full screen window is too big and it partially overlaps the Windows 11 task bar at the bottom of the screen.
Barney
10706.14 In reply to 10706.13
Hi Barney, does it also happen with MoI v4 as well? Can you please e-mail me a screenshot at moi@moi3d.com ?
Thanks, - Michael
10706.15 In reply to 10706.14
No, Version 4 is OK
I'm sending the screen shot under my real Name(!)
My perspective on this issue:
MoI 4, 5beta1, and 5beta2 were filling up the screen completely.
But, by hitting the Windows 11 upper double box at the top left, (The Maximize/Restore icon) to the right of the minimize dash, then draging the reduced MoI window left, then right,
all 3 such MoI versions then leave the Windows 11 task bar at the bottom of the screen.
Hovering over the Window 11 Maximize/Restore icon in Windows 11, pops up 6 possible window pane varieties. (Customizable???)
For Windows 11, the Window Maximize/Restore icon in MoI 5 beta does not have this hovering behavior.
(I am speaking from much ignorance :-)
Is this some new feature of Windows 11?
YES, it is called snap layouts.
https://docs.microsoft.com/en-us/windows/apps/desktop/modernize/apply-snap-layout-menu
(I am already getting annoyed by the Windows 11 "weather report +" button at lower left popping up on my screen " :-( )
EDITED: 30 May 2022 by BEMFARMER
10706.17 In reply to 10706.15
Hi barney,
> No, Version 4 is OK
So in the screenshot the main MoI window looks like it is not overlapping the task bar, the problem is that the bottom toolbar is getting a vertical scroll bar on it. This is likely a side effect from a UI mod since your UI has some modifications on it.
Please e-mail me your startup scripts folder and any other files that you have changed in the UI and I will see if I can adjust the mod for you to stop that from happening.
10706.18 In reply to 10706.9
I've look but cannot find the release notes.
Groups (something I asked for early on) are looking good.
Thanks much.
Frederick
10706.19 In reply to 10706.18
Hi Frederick, release notes for this version are at the first message of this thread, here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10706.1
Also the release notes for all v5 beta releases are collected here:
http://moi3d.com/wiki/V5Beta
10706.20 In reply to 10706.1
If possible I would like to see a way of exporting a group as individual STLs, for each object, with the file name composed of the group name and the object name concatenated, perhaps using some sort of user defined pattern. The pattern would allow a tag for the group name and the object name plus other literal characters.
This would really benefit my workflow.
As I develop a product I usually progress through various versions. If by placing the objects of a given version in a group, named after the version, I could export all the STLs needed for a selected version with the version information in the file name.
In V4 I have to include the version information in the name of each object. Moving to the next version of a product involves editing the name of each and every object, since I want the version info in the STL file name. As you can imagine that is tedious and error prone.
Frederick
10706.21 In reply to 10706.20
Hi Frederick,
The group structure is accessible to script so It should be possible to make a script that would do that.
I would need to see an example file with groups set up and the corresponding desired output to make sure I understand what it's supposed to do and you would need to specify in more detail how the user defined pattern would function.
Also if the file names were generated in this way how would you want to specify the directory for where to place the files, would that be expected to be in the group name?
Show messages:  1  2-21  22-41  42-61  62-81  …  142-145
