V5 beta May-22-2022 available now
 1-14  …  75-94  95-114  115-134  135-145
10706.115 In reply to 10706.114
Hi duble0,
> You already do the work for Mac, why you can't do it for Windows that is
> much is more popular among CAD users?
Well one reason is simply because nobody has asked for it, I think you are the first person to mention it.
10706.116 In reply to 10706.115
In Italy we say "It's like the dog biting its own tail":
I think there is a lot of prejudice about this type of devices, just read around the web many folks believe that windows arm devices are at the level of Intel Atom. So they tend to advise against them. So few buy them. Currently I can use all x64 programs for windows on my Surface Pro X, however having to run them in emulation I lose in performance and battery life. In this way a fairly performing product becomes only sufficient.
Do not think that I am here to cry because I made a wrong purchase, indeed I am very happy with my Pro X, as you can see I use Rhino quietly. But, having tried MoI a few years ago, I find that it has an interface more suited to a "touch and pen" device.
A great work in this way was made by Shapr3D that start with iPad and moved on Mac, Android ad Windows, so this software born native for ARM architecture and for touch devices. For every platform it use a subscription plan distributed by "platform stores".
You spended time for compile MoI for M1 CPU that was imposed by Apple to all new MAC products: this wasn't a decision in freedom. Now the level of performance in Windows ARM PCs is the same of M1 CPU. So the technology is sufficiently mature for ARM software on Windows; do a Windows ARM version it is a good service for your customers -> An act of love towards your customers. Furthermore Qualcomm said that for the end of 2023 they will be ready to ship to OEM the new architecture of CPU that can challenge M2 and/or M3 soc. So this technology evolving.
You can also think that I'm just a nuisance and if I care about ARM I can use Shapr3D. But i.e. I don't love Shapr3D because it use a modeling approach like Solidworks and similar and I, as thousand of people, prefers software like MoI and Rhino. I think it's a great opportunity to carve out a new market share without losing any of your current users. If you decide to release a version for Windows ARM I will be happy to spend € 350 to get it.
10706.117 In reply to 10706.116
Two questions:
1.) I am having an issue any time I edit a member of a group. Overall the ability to create named groups has massively cleaned up my workflow, however every time I select a visible object in a group that is otherwise mostly hidden (say a named solid or collection of solids) and edit this one item the entire group becomes visible once the edit has been made. Is there a way to prevent this?
As-is every time I make a change I have to wait for the entire group to display, then manually hide the entire group and show the item(s) I was working on. This means that practically I have to break any item that I want to edit out of the group before editing it and then re-group after edits are done.
2.) One of my biggest frustrations with MoI is with ortho snapping on curves that live at different Z depths. If I draw say an intersecting line and I am snapping to a curve or line at another Z height the line length will often be ever so slightly wrong (e.g. 10.0 might become 9.9999999). I assume this might be something to do with how intersections are being calculated and floating point error?
In any case, if I move everything to be coplanar prior to calculating intersections the issue goes away. It would be AMAZING if there was a "force coplanar curve intersection" for ortho snap, which could then change how ortho snaps are calculated by treating curves and lines as 2D objects on a single plane during intersection calculations to avoid these small errors.
Thanks again for the awesome new features in V5, I can't wait for the final release!
-FDP
10706.118 In reply to 10706.117
Hi FDP,
There isn't any way to prevent this at the moment but it will be fixed in the next v5 beta release.
It's hard to say what is causing this without being able to see an example of it.
Can you please post (or e-mail to me at moi@moi3d.com) a .3dm file with an example in it?
10706.119 In reply to 10706.118
Thanks Michael,
I will send you a file the next time I am able to get the snapping issue to replicate.
10706.120
I hope you are doing well :-)
I think I faced something weird and I want to share it with you.
I visited "https://www.artstation.com/artwork/28ykJx" where Christian Schweger (Zarkow) shares a link: "https://onedrive.live.com/authkey=%21AK1TMYTX1cHJDWc&id=1C86BCB357547A01%212535&cid=1C86BCB357547A01&parId=root&parQt=sharedby&o=OneUp"
there you will find a zip file called "F_Concept" if you unzip this file you will find 3 files in it. I double clicked on the file called "F_Concept.stp" obviously MOI3D opens but when I hover mouse cursor over the 3dmodel I hear a noise! it is audible when cursor moves over the model if the cursor stays still there will be no sound! and the sound is like a very low buzzing sound! Could you check and see if you get the same results? (I suggest you to use earphones/head phone) and if yes then what could be the reason?
Best,
Psygorn(Drillbit)
10706.121 In reply to 10706.120
Hi Psygorn, When I try opening your link above I get an error screen:
quote:
"This item might not exist or is no longer available
This item might have been deleted, expired, or you might not have permission to view it. Contact the owner of this item for more information."
So I'm not able to test it over here, but it's very likely to be something very specific to your hardware and not likely to reproduce on other machines.
My guess is that it could have something to do with your cooling system. Like probably some fans that used to be silent are now making some noise.
Has it been a long time since you've cleaned dust out of your computer?
10706.122 In reply to 10706.121
Thank you for your reply,
That could be the reason, however, I tried to import another relatively large stp file into MOI (of a size of 37.5 meg) I did not get the same results. But I will check my machine for the dust.
Meanwhile could you check below link? see if it works for you.
https://1drv.ms/u/s!AgF6VFezvIYck2etUzGE19XByQ1n?e=eENE0V
Best,
Psygorn
10706.123 In reply to 10706.122
Hi Psygorn, thanks I was able to get the file now. I tested over here and no noises are being generated over here.
10706.124 In reply to 10706.1
Hi Michael :)
Any news about the developing of the V5?
Which new feature are you working on?
Have you got some release date for the next betas or (maybe) for the final official version?
Thanks in advance and have a nice day!
10706.125 In reply to 10706.124
Hi Marco, sorry no news yet. I'll definitely be releasing a new beta by the end of this month since the current one expires on April 9th.
I hope that it won't be too long before the v5 final version but I don't know exactly when yet.
I've been working on some experimental things which I'm not sure will work out yet.
10706.126 In reply to 10706.125
Hi Micheal, take your time, I can't wait to see what's new you're working on.
I'm trying out a new application that uses the Parasolid kernel, and it has some useful features, maybe I'm aware of this.
10706.127 In reply to 10706.123
Hi Michael, Thanks for the reply.
10706.128 In reply to 10706.120
My first guess would be coil whine.
https://en.wikipedia.org/wiki/Electromagnetically_induced_acoustic_noise
Psygorn (DRILLBIT):
"there you will find a zip file called "F_Concept" if you unzip this file you will find 3 files in it. I double clicked on the file called "F_Concept.stp" obviously MOI3D opens but when I hover mouse cursor over the 3dmodel I hear a noise! it is audible when cursor moves over the model if the cursor stays still there will be no sound! and the sound is like a very low buzzing sound! Could you check and see if you get the same results? (I suggest you to use earphones/head phone) and if yes then what could be the reason?"
10706.129 In reply to 10706.128
Hi, Charlie (BLARBLES),
I didn't know there is a technical term for it! (although I had known this phenomenon), However, the fact that I can hear this noise whenever I open a specific file inside MOI surprises me! (I also have a decent machine) so maybe my headphone has a weird problem!? anyway, this thread is about V5 beta and maybe I should not post anymore about it here ;-)
10706.130
HI
What do you thinkk about a new function like this ?
It's one of the function from the FredoScale bar in SKETCHUP .
( the next file is a animated gif )
Chri
Size: 274.8 KB, Downloaded: 136 times, Dimensions: 335x300px
10706.131 In reply to 10706.130
Hi Chri,
It looks useful, I'd like to work on something like that at some point.
10706.132 In reply to 10706.131
thanks Michael
10706.133 In reply to 10706.132
[Request] I want delete and rename to manage Objects.
If I gave a Solid a name and made it into an object, but accidentally included a Curve, I want to recreate the object.
I think there is no way to delete an object.
Not to delete the model, of course. I just want to manage the object list.
I installed the beta of version 5 today.
A menu was added to Objects but it was only about groups. It would be nice to have delete and rename here.
Should I have write this in the V5 Wish List thread?
marzRX
10706.134 In reply to 10706.133
Hi marzRX, in the next v5 beta, when you click on something in the "Objects" section of the Scene Browser you'll get this menu pop up:
Show messages:  1-14  …  55-74  75-94  95-114  115-134  135-145
