How do I shell an open box?
All  1-7  8-9
10705.8 In reply to 10705.7
Hi Markog,
> I am not sure I understand why you would copy edges and trim them.
> Wouldn't that be a more complicated way of doing it?
I copied edges and then used the copied edge to trim the surface. So like this shown with an exaggerated distance:
> Did you create a rectangle from the copied edges or something else?
I didn't create a new rectangle, I used the ones that you had in place already and trimmed them with the copied edge.
That was a simple way because I didn't have to draw anything new, and I didn't need to know the size of the planes, I typed in the distance I wanted to cut off the ends when copying the edge to turn on distance constraint to copy it at a specific distance.
There are a lot of different ways you could do it though.
10705.9 In reply to 10705.8
I see. Thank you.
Show messages: All  1-7  8-9
