How do I shell an open box?
All  1-3  4-9
10705.4 In reply to 10705.1
Hi MRAKGR, shell in MoI works best either on a solid or for thickening an open surface it's best if it's a smooth surface.
You could try something like Edit > Separate to break it into separate surfaces and then use Shell to thicken all of those but like Burr writes above on a real box there is a little bit of empty space between flaps which might help if you had that here as well.
Reality is your best friend! ;)
10705.6 In reply to 10705.1
Hi Markog, in the attached version I've opened up that little bit of space in between the flaps by copying edge lines and using Edit > Trim and also cutting out the margin in the corners as well.
With this setup you should now be able to shell the whole thing ok, set Shell thickness = 0.05 and set Direction: Flip.
The spacing helps to keep the flaps from running in to each other.
10705.7 In reply to 10705.6
Thank you , this is a good solution.
The way I've did it is by drawing a rectangle and sliding it along the corners to make a cut using bool diff. I am not sure I understand why you would copy edges and trim them. Wouldn't that be a more complicated way of doing it? Did you create a rectangle from the copied edges or something else?
10705.8 In reply to 10705.7
Hi Markog,
I copied edges and then used the copied edge to trim the surface. So like this shown with an exaggerated distance:
I didn't create a new rectangle, I used the ones that you had in place already and trimmed them with the copied edge.
That was a simple way because I didn't have to draw anything new, and I didn't need to know the size of the planes, I typed in the distance I wanted to cut off the ends when copying the edge to turn on distance constraint to copy it at a specific distance.
There are a lot of different ways you could do it though.
10705.9 In reply to 10705.8
I see. Thank you.
Show messages: All  1-3  4-9
