Switch between dark and bright layout
All  1  2-7
10698.2 In reply to 10698.1
To switch UI theme, perhaps a shortcut key script for version 5 beta?
10698.3 In reply to 10698.1
Hi Axel, sorry I don't quite understand the question.
First of all let me make sure - are you talking about the version 5 beta and the new "UI Theme" function?
There is an option to switch it under the Options dialog, under Options > General > "UI Theme".
But there are already dark and light themes built in and you can switch just by changing the dropdown here, you don't need to copy any files just to do a switch:
10698.4 In reply to 10698.3
thanks, I was really not aware there is a v5 beta version available and this is of course a neat feature. I will it any way.
Great, thanks,
Axel
10698.5 In reply to 10698.4
Hi Axel, yes you can get the v5 beta at https://moi3d.com/beta.htm and one of the major new functions in it is a new UI Theme mechanism.
You can switch between themes there and there is also an editor for making your own customized one.
10698.6 In reply to 10698.5
I tested it and this feature is really nice :)
thanks,
Axel
10698.7 In reply to 10698.6
...I would like to add that I really like the theme management feature. It's great to get it customized in a real-time mode and you see immediately the changes you did without trial and error and restarting MOI3D after each change :))
Cheers,
Axel
Show messages: All  1  2-7
