pdf import help
All  1-2  3-7
10696.3 In reply to 10696.2
Understood!
Thanks for looking at that for me...
10696.4 In reply to 10696.3
can add to what Michael said,
as far as I know, almost every vector graphics
program has that "Text to Path" option.
10696.5 In reply to 10696.4
It is also interesting that the "microsoft pdf printer" exploded the text into geometry.
That is a little nugget to know. I think that's what threw off my thought process.
But i also was unaware of the text block limitation for MoI's import. So a plethora of little tidbits here.
Johnny: "That is weird stuff!"
10696.6 In reply to 10696.2
So: Text in an SVG or PDF file does not open to MoI 5beta. The geometry does open in MoI.
Some experiments:
Rhino 8 has a Text checkbox, and does open and show PDF text (annotation text?).
Rhino 8 also opens and shows SVG Text. (At first it seemed like it did not, but it actually does.)
Rhino8 can save the SVG or PDF as Version 5 3dm file.
Rhino8 also has a checkbox to not save "Texture" to the 3dm file.
MoI opens said (version 5) 3dm and then does show the "Text". Must now be geometric "text"?
Affinity designer2 opens the SVG and PDF's with Text.
10696.7 In reply to 10696.6
Hi Brian, yes currently text entities can be read in from .3dm or .dxf file formats.
SVG and PDF imports do not currently process text objects. If you do get text from either SVG or PDF imports the text has probably been converted into general curves and not as text entities.
Show messages: All  1-2  3-7
