Making an overlapping cut
All  1-6  7-12
10695.7 In reply to 10695.6
As a way of simplifying the problem, maybe I could understand if you could explain how to Planar this cube which had two of its adjacent faces deleted. Right now I only understand how to close the sides using Loft. For that to work I'd need to put a line where the missing edge should be though. I thought that could help Planar, but I can't join a line and a joined surface.
10695.8 In reply to 10695.7
Actually, I think I see how it could be done. I can just separate the edges that I need from the original structure by copy pasting them, draw the missing lines, join them and then Planar them. I'd have to go manually like that for each face. Is that the process I should be taking? It more complicated than using Loft, so I am not sure if I am missing something.
10695.9 In reply to 10695.8
Hi MRAKGR,
> Cutting with just the horizontal lines selected works fine. I've cut the object, separated it, isolated
> the left side and what I need to do here if figure out how to fill the hole.
The boolean will also leave behind some vertical planes inside the object and you can make use of those to
help speed things along without needing to draw in anything.
So doing a boolean difference with just these lines as the cutting objects:
Select one face and then do a right-to-left crossing window to select all these faces and use Edit > Separate to break them off:
Then hiding that broken off piece will reveal this as the hole to fill, there are already these pieces in place left by the boolean:
Ctrl+C copy those pieces and then join them together with the main piece, that will leave holes like this:
Select the whole object (not edges) and then one use of Construct > Planar will fill in those holes. Get the other half
showing and paste in the vertical planes and repeat on the other side.
EDIT: corrected crossing window direction, it's right-to-left for making a crossing window
EDITED: 17 May 2022 by MICHAEL GIBSON
10695.10 In reply to 10695.7
Hi MRAKGR, for your cube with 2 faces deleted,
For that case you would need to draw in a line and make one planar face by selecting the line and 3 edges using Construct > Planar, then join that, then for the final plane you can select the entire object and use Construct > Planar to fill that last one in.
But for the actual object when you do the boolean it leaves behind half of the planes that you need so you can use those and you don't need to draw anything extra since when they are joined the remaining planar holes are isolated from each other and so can be filled in with one use of Construct > Planar with the main object selected.
10695.11 In reply to 10695.9
Yeah, I understand now. Thank you for taking the time to answer my questions.
10695.12 In reply to 10695.11
Oops I had an error in one part that I wrote above, for the window selection that should be a right-to-left drag to make a "crossing" window (with dotted outline) that takes anything that crosses it instead of only fully contained.
Show messages: All  1-6  7-12
