v4Trial UI
All  1  2-7
10694.2 In reply to 10694.1
Hi ilyamelekhov, MoI is expecting the RussianStrings.txt file to be in Unicode format. If you convert your text file from Windows-1251 encoding to instead be either UTF-8 or UTF-16 Unicode encoding with signature mark then it should work.
I've attached a version that has been converted to UTF-8 encoding.
Hmmm, I'm not sure but it might be possible that versions older than v4 may only be expecting UTF-16 format, but v4 should work with any kind of Unicode format if the signature mark is present.
EDITED: 13 May 2022 by MICHAEL GIBSON
10694.3 In reply to 10694.2
Dear Michael,
Thank you for your fastest support!
All Great Works!
Are you interested in russian translated file (in Unicode) when I finish translation?
10694.4 In reply to 10694.3
Hi ilyamelekhov, that's great!
Yes, if you could just post it here in the forum so others could download it that would be cool.
Thanks, - Michael
10694.5 In reply to 10694.4
Dear colleagues!
I finish translate UI file into russian (in Unicode).
V4.0Trial.
Please use it.
Dear Michael,
Let me say, i can advice to take your attention into real-time-rendering and animation tools (not Styles but Shaders and lights as objects in scene).
I know major CAD/CAS use optimisation of shaders to video hard accelerators and goes to external big softs for rendering needs like VRay, Maxwell, MentalRay, KeyShot and etc...
(within not-correct Monte-Carlo (Russian Rulette))) method to cut Light-tracing calculations trees)
I think it's good for Real-time-renderings previews and big machines, but early versions of RenderMan shaders was fake but very good-looked with "fake Radiosity" (exaggerated color transfer/color bleeding)...
I miss all these tools for example in Rhino. I use Grasshopper plug-in Rhino not only for parametrization at modeling and for animation too, you can see my work here
(please see that not only animation, but also geometry generation in Grasshopper like my teapot wire at my video sample)
https://www.youtube.com/watch?v=YSi81IXqOUg&list=PLk01uGfpEyOo3BC3fjmqt713gJ8-94dX9&index=7
This is raw result of Grasshopper. Construction tree
https://disk.yandex.ru/i/ufGU3DiYEgQUIw
It can animate colours/opacity as wish at the process and when rendering animation times...
And all CADs and CASs, even Maya, doesn't calculate and doesn't limit me as modeller with collisions of objects in scenes. I very need these default constrains in each soft I used...
It's a perpective!
Good day
P.S. Michael, please replace offen pop-up window "Calculating..." to something fun like "please, take a tea time" or may be funny animated)))
EDITED: 15 May 2022 by ILYAMELEKHOV
Size: 323 KB, Downloaded: 60 times, Dimensions: 1665x1105px
10694.6 In reply to 10694.5
Спасибо Илья.
10694.7 In reply to 10694.6
Show messages: All  1  2-7
