moi autosave option
All  1-3  4-6
10692.4 In reply to 10692.2
if this hard to do full autosave option,maybe you can write the script who just use save hotkey after "some time"
10692.5 In reply to 10692.4
Hi blackboard, it would be unusual for a MoI script to work like that, usually a script runs and does some stuff and then exits. So there isn't much of an infrastructure in place to make a script like you're describing that would function very differently than regular ones.
There is a command IncrementalSave that you can put on a shortcut key that will save with the current filename but with a bumped up version number attached to the end. You can set that on something like Alt+S and use it without worrying about overwriting the current file.
10692.6 In reply to 10692.5
Many thanks
Show messages: All  1-3  4-6
