> The easiest way to help ensure that you'll get clean intersection curves is to extend objects like you did, so that they are pushing through each other by some margin instead of having surfaces that skim over each other with overlapping surface areas.
I've run into problems with booleans a few times today, and indeed, extending the cutter a bit did solve the issue. I need to remember to do it more often.  The way Moi is designed seems to induce making objects overlap though. I'll have to make it a rule to scale an object by 1.001 every time I run into an issue.
> You can get an idea of what the intersection curves look like by selecting the objects and running the Construct > Curve > Isect command to generate intersection curves. If they look messy in some area instead of making closed loops then that's probably going to be a difficult area for the booleans.
I tried doing that, but I wasn't sure how to interpret the result. I read in some Rhino docs (it is what came up while googling boolean problems) that booleaning is just automation for join, separate, delete and intersect operations. But if intersect just gives curves what use is it for booleans? For a boolean of two solids wouldn't you need an intersecting surface instead?
