Cutting small cavities into an object
All  1-9  10-11
10691.10 In reply to 10691.9
Hi MRAKGR,
> I've run into problems with booleans a few times today, and indeed, extending the cutter
> a bit did solve the issue.
Also what version of MoI are you using? There are some tune ups to booleans in the v5 beta.
I have not been able to test if those changes are significant for what you are running into
since you have not posted any model files.
> But if intersect just gives curves what use is it for booleans? For a boolean of two solids
> wouldn't you need an intersecting surface instead?
The booleans use the intersection curves to partition the 2 solids into different chunks of
connected faces and then those chunks are either combined with others or discarded
depending on what volume they are contained inside of.
10691.11 In reply to 10691.10
v4 trial.
>I have not been able to test if those changes are significant for what you are running into since you have not posted any model files.
I am trying to replicate it, but the boolean works for me now. Strange. Well, if I run into any tricky situations I'll pass them on to you for testing.
Also to everybody here, thank you for offering to look into the problem directly. Right now I am over it, but I'll probably run into something in the future and will take you up on the offer.
Show messages: All  1-9  10-11
