Projective cuts in 3d view
All  1-3  4-6
10689.4 In reply to 10689.2
I tried the first one and am wondering why is the cut slightly off? I've set the construction plane to view and drew a curve, but when it gets projected on the object during the boolean diff it is quite close to the one I drew instead of following it exactly.
10689.5 In reply to 10689.4
Hi MRAKGR, it's probably because your view is a perspective projection and the cuts are going to project in a straight direction along the construction plane normal.
If you want it to match better you might try setting the 3D view to a parallel projection instead of perspective. You can do that under Options > View > 3D view projection = "Parallel".
10689.6 In reply to 10689.5
That was it, thank you.
Show messages: All  1-3  4-6
