V5-Beta import fbx
All  1-3  4-5
10686.4 In reply to 10686.3
> Why 3dm is different than the Import FBX? (surfaces patches trimed)
It's probably from different options set under Options > SubD import options. You can have
Patch type = "Fewer patches, more control points"
or
Patch type = "More patches, fewer control points".
> Does it possible to have on the same screen, display objects with Edges and
> some objects without Edges ?
Yes, it's possible to hide edges individually. Select the edges you want to hide and use Edit > Hide.
When you do that only the selected edges will be hidden and not other edges that you did
not select.
10686.5 In reply to 10686.4
Excellent!
EDITED: 5 May 2022 by PILOU
Show messages: All  1-3  4-5
