V5-Beta import fbx
All  1  2-5
10686.2 In reply to 10686.1
That's a great result Zooen, thanks for testing it!
Very Convincing!
Why 3dm is different than the Import FBX? (surfaces patches trimed)
@ Michael
Does it possible to have on the same screen, display objects with Edges and some objects without Edges ?
10686.4 In reply to 10686.3
It's probably from different options set under Options > SubD import options. You can have
Patch type = "Fewer patches, more control points"
or
Patch type = "More patches, fewer control points".
Yes, it's possible to hide edges individually. Select the edges you want to hide and use Edit > Hide.
When you do that only the selected edges will be hidden and not other edges that you did
not select.
10686.5 In reply to 10686.4
Excellent!
EDITED: 5 May 2022 by PILOU
Show messages: All  1  2-5
