Fillet for bicycle brake block
All  1-3  4-10
10685.4 In reply to 10685.1
Hi Koi, take a look at these examples and note the spacing in the corner areas between the tabs. I think you're basically missing that spacing.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8126.3
http://moi3d.com/forum/index.php?webtag=MOI&msg=10666.4
Look at the corner areas in particular, and compare to your structure which has material in the corners where I think it needs to be empty:
That's why it's not working quite right when you fillet things, if you had the empty margin spaces in the corners it would help the fillets to be separate and not to run into each other directly like you currently have.
Hope that helps! - Michael
Here is a possibility of flow process following a bending process.
It has to be tuned to have something as you want, I think.
Tuning the curves, arcs, etc.
10685.6
Hey guys,
thank you so much for these fast answers!
Michael, I´m sorry for my bad english, but you got it, that´s what I tried to say... I understand the problem- and your solution!
Phiro, thank you as well! I will try it like that, it looks really realistic!
I love this forum, thank you so much and have a nice day!
Koi
10685.7 In reply to 10685.5
Hi Phiro,
Can you elaborate the flow process here a little more?
Marek
10685.8 In reply to 10685.7
Hi Marek,
I used Koi's file to have the profile he has made.
I made a boolean union to have a single profile.
I rebuild the curve to avoid the problems I could have with small edges next.
Now this is a seamless curve.
I extrude it to have a first solid. This solid is flat.
Next, I made the two red curves to do the flow by curves process.
for the non linear red curve, I made it with three lines joined.
I filleted the result and moved the points to have non symetrical fillet. This looks more realistic bending of metal.
With the first solid I flow it using the two red curves.
It gave me the second solid.
I use the same process to do a third solid using the second solid and the pink curves (curves made with the same method on the other axis)
I have redone it and I post the file here.
10685.9 In reply to 10685.7
Something like this ;) (sorry crossing posts)
10685.10
Thanks Phiro and Pilou,
Only now I noticed why I didn't see the Flow command work.
The new objects matched in those already made.
After I hid the 2nd and third solid I saw Flow command perfectly bending the source object.
Thanks again!
Show messages: All  1-3  4-10
